Error when using Qdrant in tool agent
Using Qdrant function “retrieve documents (As Tool for AI Agent)”
This works when directly connected to an agent.
However, when connected to an Tool AI agent, I get an error.
Error: The Tool attempted to return an engine request, which is not supported in Agents
  • n8n version: 2.2.5
  • Database (default: SQLite): Qdrant
  • Operating system: Win 11
+1
I have a AI Agent with a mcp tool that works. If I try to add in between an AI Agent Tool, I get the exact same error. If I remove the mcp tool from the AI Agent Tool, the error disappears, but no tool is executed of course.
