I’m having a problem with triggering Pushover. I get the error below:
{"context":{},"name":"NodeApiError","cause":{"name":"StatusCodeError","statusCode":400,"message":"400 - {\"token\":\"invalid\",\"errors\":[\"application token is invalid\"],\"status\":0,\"request\":\"b0a99065-7d0e-4ee1-a1ef-d03cb6169ff3\"}","error":{"token":"invalid","errors":["application token is invalid"],"status":0,"request":"b0a99065-7d0e-4ee1-a1ef-d03cb6169ff3"},"options":{"timeout":300000,"headers":{"Content-Type":"multipart/form-data"},"method":"POST","body":{"user":"[deprecated]","message":"Error: Example Workflow failed!","priority":-2,"url":"[deprecated]","token":"[deprecated]"},"qs":{},"url":"https://api.pushover.net/1/messages.json","json":true,"simple":true,"resolveWithFullResponse":false,"transform2xxOnly":false},"response":{"statusCode":400,"body":{"token":"invalid","errors":["application token is invalid"],"status":0,"request":"b0a99065-7d0e-4ee1-a1ef-d03cb6169ff3"},"headers":{"server":"nginx","date":"Wed, 21 Sep 2022 08:37:50 GMT","content-type":"application/json; charset=utf-8","transfer-encoding":"chunked","connection":"close","x-frame-options":"SAMEORIGIN","x-xss-protection":"1; mode=block","x-content-type-options":"nosniff","x-download-options":"noopen","x-permitted-cross-domain-policies":"none","referrer-policy":"strict-origin-when-cross-origin","access-control-allow-origin":"*","access-control-allow-methods":"POST, OPTIONS","access-control-allow-headers":"X-Requested-With, X-Prototype-Version, Origin, Accept, Content-Type, X-CSRF-Token, X-Pushover-App, Authorization","access-control-max-age":"1728000","cache-control":"no-cache","x-request-id":"b0a99065-7d0e-4ee1-a1ef-d03cb6169ff3","x-runtime":"0.005763"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"api.pushover.net","port":443,"hostname":"api.pushover.net","hash":null,"search":null,"query":null,"pathname":"/1/messages.json","path":"/1/messages.json","href":"https://api.pushover.net/1/messages.json"},"method":"POST","headers":{"Content-Type":"multipart/form-data","accept":"application/json","content-length":191}}}},"timestamp":1663749470874,"message":"Bad request - please check your parameters","node":{"parameters":{"resource":"message","operation":"push","userKey":"u3fcgbb9pcj5dw8tmuzzs4s5a4hccm","message":"=Error: {{$json[\"workflow\"][\"name\"]}} failed!","priority":-2,"additionalFields":{"url":"={{$json[\"execution\"][\"url\"]}}"}},"id":"9a7aa466-11ec-4d93-8c67-2f7ea08187c5","name":"Pushover","type":"n8n-nodes-base.pushover","typeVersion":1,"position":[240,100],"credentials":{"pushoverApi":{"id":"6","name":"Pushover account"}}},"httpCode":"400","description":"application token is invalid"}
I’ve tested my credentials with other methods and they have no problem.
Any ideas?
