I am currently having a problem with the embedding portion of my workflow. I am only getting a general ‘fetch failed’ error and no additional supporting details.
Digging into the container logs I retrieved the following error message, but there is little clarity without digging into the code.
2024-10-29 18:42:18 fetch failed
2024-10-29 18:42:18 TypeError: fetch failed
2024-10-29 18:42:18 at node:internal/deps/undici/undici:13185:13
2024-10-29 18:42:18 at post (/usr/local/lib/node_modules/n8n/node_modules/ollama/dist/shared/ollama.9c897541.cjs:114:20)
2024-10-29 18:42:18 at Ollama.embed (/usr/local/lib/node_modules/n8n/node_modules/ollama/dist/shared/ollama.9c897541.cjs:396:22)
The workflow is as follows:
I am using the same embedding node in another segment of the workflow that interfaces with OpenWebUI to query the qdrant vector db and it returns with no error, though there is no content to return.
Additional notes:
I am currently embedding the content of 1984 by George Orwell which approximates to 585Kb in a text file.
- n8n version: 1.64.2 - Yes, I know it is out of date, but ever so slightly
- qdrant is the db in question. The postgres connection is working flawlessly for chat history
- File changes in a directory are detected, which triggers the above workflow.
- Current execution framework is Docker Desktop, though once development is implemented the workflow will be migrated to an Unraid server, also executing via docker.
- OS in question is Win 11, although bunkered within Docker.
Please advise to any additional information I can provide to assist with diagnosing this issue. I have been banging my head against the wall for days.
