Error with Summarization Chain and Mistral AI
I have used the workflow template provided here:
When used with the Mistra AI Model, the Summarization node throws the error: “Cannot read properties of undefined (reading ‘text’)”.
TypeError: Cannot read properties of undefined (reading 'text')
    at NoOpOutputParser.parseResult (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/node_modules/langchain/node_modules/@langchain/core/dist/output_parsers/base.cjs:54:42)
    at NoOpOutputParser.parseResultWithPrompt (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/node_modules/langchain/node_modules/@langchain/core/dist/output_parsers/base.cjs:20:21)
    at LLMChain._getFinalOutput (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/node_modules/langchain/dist/chains/llm_chain.cjs:124:55)
    at LLMChain._call (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/node_modules/langchain/dist/chains/llm_chain.cjs:159:46)
    at processTicksAndRejections (node:internal/process/task_queues:95:5)
    at LLMChain.call (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/node_modules/langchain/dist/chains/base.cjs:120:28)
    at async Promise.all (index 1)
    at MapReduceDocumentsChain._call (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/node_modules/langchain/dist/chains/combine_docs_chain.cjs:188:29)
    at MapReduceDocumentsChain.call (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/node_modules/langchain/dist/chains/base.cjs:120:28)
    at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/chains/ChainSummarization/V1/ChainSummarizationV1.node.js:207:30)
    at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:730:19)
    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:662:53
    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1064:20
Version: tested on 1.29.1 and 1.31.0
Database: Postgres and SQL Lite
n8n EXECUTIONS_PROCESS setting: default
Running n8n via Docker
Operating system: Debian 11
Hey @denobeno,
The good news is while I was reproducing this another team member popped in this PR: fix: Mistral package update, tools issue fix by michael-radency · Pull Request #8847 · n8n-io/n8n · GitHub which fixes it so it looks like for now it will be a case of waiting for the next release.
Hi @Jon,
first of all, thanks for looking into it. That’s great to hear, I’m glad the problem could be fixed so quickly.
I’m looking forward to the release :slight_smile:
New version [email protected] got released which includes the GitHub PR 8847.
The error is not ther anymore but it is super super long to wait for an answer…
