Error workflow is not executed
Hi,
I created an Error workflow which works for itself (but cannot be activated). I added the Error workflow to the settings of another workflow where I want to test it using wrong credentials in an HTTP Request (which then produces an 401 error).
Unfortunately, the error workflow is not executed.
Any idea how to track this down?
(Or does this not work if I test a workflow using “Execute Workflow”?
Thanks and best,
Jo
Did you active the workflow that is generating the error? Just tested and it’s working just fine for me.
Yes, error workflows execute only when in production mode, so if the workflow is active. They do not run when testing/running manually.
Thank you, this helps!
