Eval method not working in 0.183.0
Hi Community!
while i was debugging one of our workflows, i stumpled upon some weird behaviour with the eval method. it seems to be disfunctional in newer versions of n8n.
eval method always throws an error on execution on n8n version 0.183.0. ive tested it with an example from w3schools, and also tried to use $evaluateExpression, but the latter is somehow not doing anything (not sure if im using it correctly thou :smiley: )
the weird thing about that is - i’ve tested the exact same workflow with an older version of n8n (0.107.0) and it works perfectly fine. i have included my workflow below.
on the newer version the error message reads: “x is not defined”
Please share the workflow
ERROR: x is not defined [Line 7]
Details
Stack
ReferenceError: x is not defined
    at eval (eval at apply (/usr/local/lib/node_modules/n8n/node_modules/vm2/lib/setup-sandbox.js:371:10), <anonymous>:1:1)
    at eval (<anonymous>)
    at Object.apply (/usr/local/lib/node_modules/n8n/node_modules/vm2/lib/setup-sandbox.js:371:10)
    at /usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Function:7:16
    at /usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Function:13:2
    at BaseHandler.apply (/usr/local/lib/node_modules/n8n/node_modules/vm2/lib/bridge.js:479:11)
    at NodeVM.run (/usr/local/lib/node_modules/n8n/node_modules/vm2/lib/nodevm.js:425:23)
    at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Function/Function.node.js:96:31)
    at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/src/Workflow.js:594:51)
    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/src/WorkflowExecute.js:537:64
version with ERROR:
  • **n8n version:**0.183.0
  • **Database you’re using (default: SQLite):**not sure, probably default
  • **Running n8n with the execution process [own(default), main]:**not sure, probably default
  • **Running n8n via [Docker, npm, n8n.cloud, desktop app]:**Docker
version with NO ERROR:
  • **n8n version:**0.107.0
  • **Running n8n via [Docker, npm, n8n.cloud, desktop app]:**n8n cloud
let me know if theres any more information required, iirc in versions 0.182.0 and 0.181.0 it was also not working, but unfortunately i currently dont have access to instances running these versions.
thank you for reading! :slight_smile:
edit: we’ve just updated to the latest version (0.185.0) and the issue still persists.
Hey @strdl,
Try using the below line, It looks like the variable is not being passed in for some reason.
let text = `${x} * ${y}`;
hi @jon,
thank you for your reply! that actually worked. still weird that it doesnt work the same way it used to, but i can live with that :smiley:
thanks again and have a good day!
