I currently have a normal instance with MySQL Database which runs in normal Mode. I would like to apply the scalable configuration with workers to it. Does anyone have an example of the configuration by using nginx? I am not sure how to configure Load Balancing for the worker processes.
You mean the configuration described at Scaling n8n | Docs, right? Which load balancer are you planning on using? I haven’t configured this myself, but maybe someone in the community has an example to share.
So with the webhook backends that you need to loadbalance the example on the nginx website is a good starting point: Simple Load Balancing | NGINX
We don’t have anything specific to n8n for this one but if you are already using NGINX for loadbalancing websites / web services the same config theory should apply.
