I recently updated my n8n instance on TrueNAS to 2.3.2 and I had a workflow that was using the Execute Command node that worked fine until this update. Where it used to work I now get
spawn /bin/sh EACCES
as the error message. Command execution works fine from the command line, I’ve tested spawning the /bin/sh executable as well as passing a command to it such as /bin/sh -c “echo” and both work.
“errorMessage”: “Forbidden by access permissions, make sure you have the right permissions”,
“errorDetails”: {
“rawErrorMessage”: [
“spawn /bin/sh EACCES”
“n8nDetails”: {
“nodeName”: “Execute Command”,
“nodeType”: “n8n-nodes-base.executeCommand”,
“nodeVersion”: 1,
“itemIndex”: 0,
“time”: “1/9/2026, 10:21:33 PM”,
“n8nVersion”: “2.3.2 (Self Hosted)”,
“stackTrace”: [
“NodeOperationError: Forbidden by access permissions, make sure you have the right permissions”,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_8da18263ca0574b0db58d4fefd8173ce/node_modules/n8n-nodes-base/nodes/ExecuteCommand/ExecuteCommand.node.ts:102:12)“,
" at processTicksAndRejections (node:internal/process/task_queues:105:5)”,
" at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1045:8)“,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1226:11)”,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1662:27",
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_ec37920eb95917b28efaa783206b20f3/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2297:11"
- n8n version: 2.3.2
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker
- Operating system: TrueNAS Scale
