In our system, we use multible subworkflows chained together. One of these subworkflows for some reason always executes the next workflow 5 times sometimes, sometimes just once, even though it just receives one item and is set to only execute the next once.
- n8n version: 1.123.22
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
- Operating system: MacOS
The issues is that you have set waitForSubWorkflow: false. Set it to true instead.
If you have upstream changes or feed back to the beginning of the chain it stacks multiple executions before the previous one finished
Hi @MoritzSchoelderle I think your setup really prevents that node from being executed more than 1 time, but as you are saying that it still executes more than one time sounds like a problem, consider upgrading to the latest 2.x.x version and that would should solve the issue.
But doesn’t that mean that the node workflow will stay running until all subworkflows are finished. That’s a problem for us because that workflow then blocks one execution that we might need for another run.
