Execute Workflow - UI keeps running with success or failures - No Icon Light up
I’m self-hosting on Google Cloud > Cloud Run through a private VPC With an external HTTPS load balancer.
The execution keeps running even after successful or failure executions. I have to manually stop execution which produces a 500 error in the logs.
Also, the node icons stopped light up and data was only visible in the Executions tab.
All of these started around the n8n@1.123.0 update,
Portions of the workflow light up after n8n@1.123.6 update and data is visible on the canvas without having to go to the Executions tab. However, the executions still run without stopping.
Nothing changed with the 2.0 update.
I added N8N_PUSH_BACKEND=sse as a possible solutions and it caused the workflows to lose connection.
Manual stop produces POST 500 error.
  • n8n version: 2.0.3
  • Database (default: SQLite): PostgreSQL 13
  • n8n EXECUTIONS_PROCESS setting (default: own, main): deafults
  • Operating system: N/A - Container (?)
This sounds like a bug related to workflow execution handling in the UI. It’s good that you’ve seen improvements with the updates to 1.123.6 - it seems like the issue might be related to how workflows were managed before that version. Sharing your workflow JSON would help pinpoint the exact nodes causing the problem.
