Execution Data Bloat and Posters I/O spikes
After enabling execution pruning, I’m seeing heavy I/O spikes during deletion cycles. Is manual vacuuming expected for Postgres-backed setups?
Yes, this is expected behavior.
When large volumes of execution rows are deleted:
Postgres marks space as reusable.
It does not immediately reclaim disk space.
This increases table fragmentation and I/O.
You should:
  • Run regular VACUUM (or rely on autovacuum tuning)
  • Consider VACUUM FULL during maintenance windows
  • Reduce retention window if execution storage is not required
This is a scaling consideration, not a workflow issue.
