ExecutionId ternary seems to not be supported anymore
Hello,
I was using a workaround based on a ternary condition related to $executionId # as you can see in the screenshot below. Basically to return a specific variable if the Id # is even or odd to rotate between multiple integrations.
Since I upgraded my n8n version to the latest version stable it doesn’t seems to work anymore as the ternary is resulting to false in both cases.
Do you have any thoughts to troubleshoot this ?
  • n8n version: 1.32.2
  • Database : SQLite
  • Running n8n via n8n cloud
Ok my bad - the execution_id used for the ternary initially was stored from another workflow - resolved
