The Idea:
Implement the option to hide/show all Notes for Flows as an extended feature. Additionally, consider adding a box around each Node and its corresponding Note to make it clear that they belong together.
My Use Case:
Documenting Build Workflows.
Why this would be beneficial:
Currently, Notes are cut off, as shown in the image below:
The text should read, “The documentation of this node is too long.”
Using sticky notes as an alternative wouldn’t solve the problem because:
a) They are not linked to the Node, which requires extra effort when moving or copying the Node.
b) They are not hideable.
