Expression Window for SQL Node
The idea is:
Please add an expression window to the MS SQL Execute Query Node
My use case:
I am trying to debug an SQL script but without an expression window, I am unable to take the output with the variables populated to look at it in more detail. The little window that pops up at the bottom with the variables polluted is OK but there is no way to copy the contents of this window or expand this window.
This would allow copying the full script with the variables populated so that it can be run in management studio to check for any syntax errors, etc.
