Is it possible to request an extension of the n8n cloud trial? I’m studying for certifications and would need additional time. Who should I contact? Thanks.
Hello @FrancescoG. Not sure about the cloud option, but you could try the docker option on premises. It’s pretty simple to setup and you wouldn’t have this issue.
Hi @FrancescoG,
I have an extra coupon code for 1 Month of n8n Cloud Pro,
I won’t be using it, and I think you could put it to good use, If you still need it, feel free to send me a DM (it’s free, of course).
Thank you for your seggestion. I’ll go deep in the topic to understand how to set the docker🙏
Thank you I’ll contact you:)
