Extract from CSV will be combined
Problem
The Extract from CSV will be combined in output.
Workflow:
I do not want to combine the result.
I want a separate xls file for each binary file.
Do you have any ideas?
  • n8n version: 1.38.1
  • Database: SQLite
  • n8n EXECUTIONS_PROCESS setting (default: own, main): i dont know
  • Running n8n via: Docker Compose
  • Operating system: Linux Debian vm
@minnovation , try using the Loop node
Thank you, I had already tested it with Loop.
I have now added a switch and now it works with the loop.
