Extract gmail attachments and save to drive
How to download all the attachments which is returned by the gmail node as binary files.
I want to download all the files to my google drive and add the file links to airtable.
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
  • Database you’re using (default: SQLite):
  • Running n8n with the execution process [own(default), main]:
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]:
Hi @Sanya_Raphael, do you need someone to build the workflow for you? If so, that’d be a job for an n8n expert:
If you already have a workflow built yourself, could you share it and confirm what exactly isn’t working for you? And could you also confirm which version of n8n you are running?
