Extract Node does not extract multiple files in a loop node
The extract node cant extract an array of files. Only the first file was extracted.
No error message
I have 2 csv files in OneDrive and i expect the 2nd one to be extracted too.
  • n8n version: 1.79.3
  • Operating system: Linux
Hey @Manage_Bnb have you tried to do it without the loop? If you have 2 items, n8n will automatically run each step for each item and you don’t need a loop.
Yes, I tried using without the loop. n8n will auto combine the extracted file. This happened because this files have the same data structure.
Already resolve this. I still used the loop but I added a code where it updates the list of files to be extracted. Before, it extracts from the same file because I’m not telling n8n that this file’s data is already extracted. I added code node that will tell this to n8n and it worked
