Facing problem for past 1 month. HELP
I am banging my head because of this problem for past 1 month. So i have to build this ai voice assistant using vapi. So i used n8n webhook and hooked to vapi to receive data.
I run webhook and test convo with my assitant, but webhook get no response. The convo is ended, i wait untill time ran out, but nothing. (https://youtu.be/odR0NbbtuLw)
then i made another assistant, when i start my webhook, and start my convo with my assistant, the moment it or i say hello, webhook gives output. but its null output. The output i am looking to recive in n8n doesnt get it. The convo is still going on but webhook gave output and it stops. (https://youtu.be/CXUXHu8am6w)
I used online webhook and hooked it to vapi, and it receives data instantly.
From your youtube video, the first webhook and second webhook are both set to respond immediatly. The fist video receives a webhook and responds with presumably 200 - OK. There is no output because you’ve not defined anything to do after the incoming webhook has received anything.
On the second one that did not receive a webhook call, I’m not sure when Vapi is supposed to initiate the webhook so can’t help there.
Yes. I have sent email to them. Waiting. Lets see what they say
no sir. still no solution
