Hi everyone,
I’m using the NocoDB get many node with filter by formula.
When I use a simple combination like this, it works fine:
(nombre_de_contact,lt,4)~and(date_de_contact,isWithin,pastMonth)
However, when I try to use nested logic with both ~or and ~and, like this:
((nombre_de_contact,is,null)~or(nombre_de_contact,lt,4))~and((date_de_contact,is,today)~or(date_de_contact,isWithin,pastMonth))
…it throws an invalid filter format error.
Is there a known limitation or specific syntax for combining ~or and ~and in NocoDB filters?
Thanks in advance!
Invalid filter format.
- n8n version: 1.95.3
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Running n8n via (Docker, npm, n8n cloud, desktop app): Container
- Operating system: NixOS 25.05
