Fingerprint issues after rebuilding docker container for n8n
I have rebuilt the docker container for n8n on my self-hosted SSH on GCP, and now I cannot use the community features that are free to unlock with the activation key. My fingerprint from the logs is:
a564f6be88856da9690dc37c3bce40bd9570372075f528f9887da59838574333
Activation failed
Failed to activate license: license activation failed: device fingerprint mismatch
  • n8n version: 1.71.3
  • n8n EXECUTIONS_PROCESS setting (default: own, main): ?
  • Running n8n via (Docker, npm, n8n cloud, desktop app): docker on google cloud platform
  • Operating system: Ubuntu
I can’t find anywhere else in this forum to post this question. :frowning:
Does anyone have a contact for reaching out regarding getting a fingerprint matched to a community activation key? TIA
Welcome to the community @POZENyoga !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
Here’s the answer to the same problem, Help with n8n community license, unable to activate after re-deploy - #2 by ihortom.
In short,
  1. Run CLI command n8n license:clear
  2. Restart n8n instance
  3. Re-enter the license key
