Before anything, I’m using Zapier and Microsoft Power Automate and was looking for something like N8N, maybe requires a little bit more knowledge but seems to be powerful, thanks.
Trying to understand the use of the Pipedrive Integration, I added the Pipedrive node, set Resource PERSON and the default Operation GetAll.
I would like to use some parameters detailed in Pipedrive API v1 Reference and I don’t know how can I add the parameters or if the integrations only works getting the whole items and I have to use functions to filter the result.
For instance, I want to add the parameter first_char for filtering the PERSONS results.
I think is a personal lack of understanding, maybe I receive a RTFM
