First webhook authorization never works
Hey guys,
I really cant understand what is going on with the initial webhook. No matter what settings I use, the “Authentication” option (which is 100% set up properly) in the first webhook NEVER works and passes the data. The only time it works is when I add an additional HTTP Request and enter the same saved Authentication information. I tried a new workspace, tried to create another initial webhook, I keep getting the “Authorization data is wrong!” error in the logs. I am confused on how and why the first authentication config never works. I am using the latest n8n
Version: 1.64.3
SQLite
Docker
Executions process is off
Debian 11.9
Hey @webmaster101,
Can you share a workflow so we can try and reproduce this? I tried following along but I ended up with a webhook node that was working as expected.
