Hi there,
I installed n8n for the first time this week. For my first workflow, I wanted to connect ClickUp and Clockify, so I could create a new Project in Clockify whenever I created a new List in ClickUp.
But I am having trouble getting the ClickUp Trigger to register anything.
I believe that I have set up the API Token properly, because when configuring the trigger, it finds the name of my Team.
Under the Events dropdown, I have tried both *
and list.created
. I then save the workflow, click Execute Node, and add a list in my ClickUp account. But no results ever appear.
I tried setting up a Clockify Trigger to see if I could actually get a trigger to work. And that returned results.
Here is the basic workflow for the ClickUp Trigger (team and webhooks changed):
"name": "ClickUp Trigger Test",
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
250,
300
"parameters": {
"team": "1234567",
"events": [
"filters": {}
"name": "ClickUp Trigger",
"type": "n8n-nodes-base.clickUpTrigger",
"typeVersion": 1,
"position": [
400,
300
"webhookId": "d94b94f6-f7fc-4c75-843d-7b2f448c2059",
"credentials": {
"clickUpApi": "ClickUp"
"connections": {},
"active": false,
"settings": {},
"id": "4"
I’ve looked through the documentation as best as I can, and I can’t quite figure out what’s going on.
This is my first workflow attempt, so I’m sure I’m doing something wrong.
Thanks for any help you can offer.
