The idea is:
right now the merge node has two modes that can be compared to SQL join:
- merge by key - behaves like inner join
- multiplex - behaves like outer join
Please add left join, which retains items from the first input when there’s no matching item in the second input
My use case:
My items have a field, say company_name, that I need to fill based on another field which might be empty, say, company_id.
I take all companies and try to merge it using company_id as the matching field.
If company_id is missing or otherwise not matching, I’d like to keep that item in the output.
Left join is quite common in SQL and merge node looks like it’s supposed be something similar
