Form ending in waiting mode!
Welcome aboard, I hope to be happy with ur new family
Check this code:
Why i can’t find the “Limit Waiting Time” option ini my Form node?
even when i try to pasted in the workflow’s code
try to update to the latest version. then check again
Oh ok. Thx.
Suggestion: it will be better if the time limit is also able to identify if the required field is empty or not. if it empty, then it should stop the flow.
good idea… but the best is not to complete at all… its validation step
that even better.
so the time limit will act as time limit for the user to input the form.
yes steve, but the problem is not in this part. It’s the mechanism of ending the form
