I think this makes sense!
For numeric fields, if you do not enter any value, it defaults to 0
For text fields, if you do not enter any value, it returns an empty string
Can you explain a bit more? Maybe I’m missing something..
Is there are a way to not have it output 0 if i do not enter any value and show 0 only if i set 0?
Currently if a user has an option to set a number and they will not set it will output 0 and will overwrite the current number they have on file with 0.
Same time we need to allow then to select a 0 if they want to set it 0.
There are no way for me to know if the user set a 0 or they have not select anything, so i cannot filter it to stop the values in my system to be overwritten with 0
Cannot do that, the number field is an actually a currency field for ClickUp so the numbers can be between 0 and $1m and cents.
I hope for the new version of n8n where we can define the default value and this will be prefilled from the account number so it will not be 0 if there are something there only if the user will actualy set it to 0.
