I install a fresh install on Docker, setup first workflow to connect to imap and print out. At first test, n8n show workflow can read email from imap. Then 30 sec later, server down.
Console show this
Initializing n8n process
n8n ready on 0.0.0.0, port 5678
Version: 0.197.1
Start Active Workflows:
- My workflow (ID: 1)
=> Started
Editor is now accessible via:
http://localhost:5678/
Press “o” to open in Browser.
/usr/local/lib/node_modules/n8n/node_modules/imap-simple/lib/imapSimple.js:212
var encoding = part.encoding.toUpperCase();
TypeError: Cannot read properties of null (reading ‘toUpperCase’)
at /usr/local/lib/node_modules/n8n/node_modules/imap-simple/lib/imapSimple.js:212:46
at processTicksAndRejections (node:internal/process/task_queues:96:5)
- **n8n version: latest with docker
- **Database you’re using (default: SQLite): SQLite
- Running n8n with the execution process [own(default), main]:
- **Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
