FTP node consumes a lot of memory and connections
It would help if there was a node for:
My use case:
When I use FTP Node it consume many memory!
               if (protocol === 'sftp') {
				await sftp!.end();
			} else {
				await ftp!.end();
		} catch (error) {
			if (this.continueOnFail()) {
				return [[{ json: { error: error.message } }]];
			throw error;
end() method should be call at on the finally block code.
It
Good spot, I will look into this shortly.
