G Suite Admin node not respecting error flow
When using the G Suite Admin node to search for a user ID the node is not respecting error handling options.
If the search results in a response of:
ERROR: The resource you are requesting could not be found
404 - {“error”:{“code”:404,“message”:“Resource Not Found: userKey”,“errors”:[{“message”:“Resource Not Found: userKey”,“domain”:“global”,“reason”:“notFound”}]}} - Resource Not Found: userKey
it will halt the workflow and fail by default, but if i choose to "Continue (user error output), it still following the “Successful” output regardless if it error and it just passes the output of the previous node.
  • n8n version: 1.25.1
Hey @Dan_Westness,
Thanks for reporting this one, I have popped in a PR which will fix this (below). Once reviewed and merged it will be available in a future release.
Thanks! I will update once fully released.
New version [email protected] got released which includes the GitHub PR 8499.
I have updated to 1.31.2 and will confirm that this issue has been corrected now.
Thank you!
