Gemini pro temperature
Hi
i use gemini pro 1.5. on the preview https://aistudio.google.com/
we can put temperature to 2, but not with n8n.
any reason ?
Hi @nusquama, this is a hold-over from the past and I’ve created an internal ticket to update this [AI-300] Thanks for bringing this to our attention, really appreciate it :slight_smile:
hi,
do you have new about temperature on gemini ?!!!
thanks
Will ask internally and get back to you! @nusquama
