Hello, I have tried triggers on a Docker image, but they don’t seem to work properly. The Telegram trigger works a few times and then stops working. I tried running it through a tunnel, but couldn’t find a solution. As a last resort, I installed it on a VPS to see if it would make any difference, but the issue persists. The RSS trigger also doesn’t work. Is this a normal situation? If anyone has encountered this before, can they please help? What could be the possible cause of this issue? I am not a beginner in terms of computers, but I haven’t been able to solve this problem.
Is there anyone who can help?
Sadly no idea what is going on with your setup. A good starting point for being able to figure situation out would be to fill the topic template so that we get a better understanding how you run n8n and what version.
