GET /api/v1/workflows tags parameter does not filter results - returns workflows without specified tags
Summary
The tags query parameter in the GET /api/v1/workflows endpoint does not filter workflows as documented. When requesting workflows with specific tags, the API returns all workflows including those with no tags at all.
Environment
  • n8n version: 1.112.0
  • API endpoint: GET /api/v1/workflows
  • Deployment: Docker (self-hosted)
Steps to Reproduce
  1. Create 3 workflows in n8n:
    • Workflow A: tagged with “approvals”
    • Workflow B: tagged with “approvals”
    • Workflow C: no tags
  2. Make API request with tags filter:
curl -H "X-N8N-API-KEY: <your-api-key>" \
  "http://localhost:5678/api/v1/workflows?active=true&projectId=<project-id>&tags=approvals"
Expected Behavior
The API should return only Workflow A and Workflow B (workflows tagged with “approvals”).
Actual Behavior
The API returns all 3 workflows, including Workflow C which has no tags.
From the response, I can confirm all workflows are returned:
  "data": [
    {"id": "...", "name": "Workflow A", "tags": [{"name": "approvals"}]},
    {"id": "...", "name": "Workflow B", "tags": [{"name": "approvals"}]},
    {"id": "...", "name": "Workflow C", "tags": []}
API Documentation Reference
According to the OpenAPI spec (n8n-public-api.yaml lines 476-484), the tags parameter is documented as:
- name: tags
  in: query
  required: false
  explode: false
  allowReserved: true
  schema:
    type: string
    examples:
      - test,production
Impact
This makes the tags parameter unusable for filtering workflows by domain/category. Users must fetch all workflows and filter client-side, which is inefficient for large workflow collections.
Workaround
Currently implementing client-side filtering after fetching all workflows from the API.
Hi @Ethan_Tran
I’ve tested it on 1.119.1
used command:
curl -H “X-N8N-API-KEY:<API_KEY>” “https://<MY_DOMAIN>/api/v1/workflows?active=true&tags=ai” | jq “.data.name”
where jq helps you format data.
Looks it filters data as it should be filtered.
Is it possible to update n8n instance on your side?
