GMAIL - Filter for multiple sender
I would like to the GMAIL trigger to be activated when emails are received any of the sender from a list (10+ senders). Is there are way to specify the filter/sender parameter all in one node without having to make multiple trigger nodes?
There is not error message. When I put multiple emails separated by either a comma, a semicolon the, node returns “No Gmail data found
We didn’t find any data in Gmail to simulate an event. Please create one in Gmail and try again.”
It did not return anything.
Hi @Papavee_Phongsopa
According to Search operator , you can try using one of the following options:
Using OR:
from:[email protected] OR from:[email protected] OR from:[email protected]
Using { } grouping:
{from:[email protected] from:[email protected] from:[email protected]}
Try either of these in the Filters Search field:
