When using the google drive trigger to watch a folder for filecreated, when you upload multiple files at the same time, the trigger does not fire for each file, but only fires once.
- n8n version:
- Database (default: SQLite):
- Operating system:
- **n8n version: 1.27.2 **
- Database: postgres
- n8n EXECUTIONS_PROCESS setting (default: own, main): queue
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker
- Operating system: ubuntu 20
This may just be the nature of the API, that if you upload multiple at the same time it’s considered one upload action.
You may be able to just add in an if node right after the trigger to check if there is more than one file so you could get it set up so that it doesn’t matter
Let me know if you know what i mean
