Nodes of the type langchain.embeddingsGoogleGemini and langchain.lmChatGoogleGemini, those that have the form of a circle, do not respond to the installed proxy settings. At the same time, other nodes, when accessing GoogleGemini, which are rectangular, perceive proxy settings.
the settings Compose file of the proxy are as follows:
- HTTP_PROXY=http://…@..:..
- HTTPS_PROXY=http://…:…@…:…
- NO_PROXY=localhost,127.0.0.1,postgres,.local,10.,192.168.,172.16.,172.17.,172.18.,172.19.,172.20.,172.21.,172.22.,172.23.,172.24.,172.25.*,172.26………………
[GoogleGenerativeAI Error]: Error fetching from https://generativelanguage.googleapis.com/v1beta/models/text-embedding-004:embedContent: [400 Bad Request] User location is not supported for the API use.
- n8n version: 1.109
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Operating system:
