Hello,
I’m running a GraphQL node and face some interesting behavior. Lets say I have three requests executed. If all requests fail, the node returns a valid response like this here (this was with two requests):
"errors": [
"message": "6 is not a valid NullText",
"path": [
"createPropressale"
"extensions": {
"code": 400,
"errors": []
"data": null
"json": {
"pairedItem": {
"item": 0
"json": {
"pairedItem": {
"item": 1
"errors": [
"message": "9 is not a valid NullText",
"path": [
"createPropressale"
"extensions": {
"code": 400,
"errors": []
"data": null
"$error": {
"timestamp": 1744264087818,
"name": "NodeApiError",
"description": null,
"context": {}
"itemIndex": 1
But as soon as I add another successful request, the node does not give me any valid output anymore:
So that happens when in the batch there are:
- failing requests > 1
- successful requests > 0
1 failing and 1 successful works. All failing works. All successful works.
- n8n version: 1.67.1
- Database (default: SQLite): Postgres
- n8n EXECUTIONS_PROCESS setting (default: own, main): main
- Operating system: Ubuntu 24
