It would seem the GraphQL node is faulty in that it doesn’t pass along variables. Here’s what the designer says my variables are:
Here’s what the GraphQL server gets:
"type":"http-log",
"timestamp":"2020-11-18T16:54:31.707+0000",
"level":"error",
"detail":{
"operation":{
"user_vars":{"x-hasura-role":"admin"},
"error":{
"path":"$.variableValues",
"error":"expecting a value for non-nullable variable: o of type: fivetran_connectors_insert_input! in variableValues",
"code":"validation-failed"
"request_id":"6703726f-00b3-991f-a4d3-4235bdd3fb9f",
"response_size":172,
"query":{
"variables":{},
"operationName":"UpsertFivetranConnector",
"query":"mutation UpsertFivetranConnector($o: fivetran_connectors_insert_input!) {\n insert_fivetran_connectors_one(\n object: $o, \n on_conflict: {\n constraint: connectors_pkey,\n update_columns: [setup_state, data]\n }) {\n id\n }\n}\n"}},
"http_info":{
"status":200,
"http_version":"HTTP/1.1",
"url":"/v1/graphql",
"ip":"127.0.0.1",
"method":"POST",
"content_encoding":null
Note the distinct lack of variables passed along.
Definition:
"parameters": {
"endpoint": "http://analytics-db-m2m/v1/graphql",
"requestFormat": "json",
"query": "mutation UpsertFivetranConnector($o: fivetran_connectors_insert_input!) {\n insert_fivetran_connectors_one(\n object: $o, \n on_conflict: {\n constraint: connectors_pkey,\n update_columns: [setup_state, data]\n }) {\n id\n }\n}\n",
"variables": "={\n \"o\": {\n \"data\": \"{{JSON.stringify($json[\"data\"])}}\"\n \"setup_state\": {{$json[\"data\"][\"status\"][\"setup_state\"]}},\n \"remote_id\": {{$json[\"data\"][\"id\"]}}\n }\n}",
"operationName": "UpsertFivetranConnector",
"headerParametersUi": {
"parameter": [
"name": "x-hasura-admin-secret",
"value": "={{ $env.LOGARY_M2M_HASURA_ADMIN_SECRET }}"
"name": "Insert Connector",
"type": "n8n-nodes-base.graphql",
"typeVersion": 1,
"position": [
940,
130
There’s a silent fail here:
Perhaps this could be logged?
