GraphQL node thowring ERROR: _a.map is not a function
i was getting below error in graphql node
TypeError: _a.map is not a function
    at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/GraphQL/GraphQL.node.js:462:101)
    at processTicksAndRejections (node:internal/process/task_queues:95:5)
    at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:730:19)
    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:662:53
    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1064:20
however the same flow is working previous n8n cloud instance.
the current version is 1.29.1.
please check this
Hi @Rohit_Mali
Please don’t forget to include the graphql query and/or the workflow.
  products(first: 55 query: "sku:VOLRBM23261 OR sku:HARBM02 ") {
    edges {
      node {
        id
        title
        variants (first: 2) {
          edges {
            node {
              sku
              inventoryItem {
                inventoryLevels(first: 1) {
                  edges {
                    node {
                      available
                      location {
                        name
above was the query i used
