Guys pleas add Miro node ASAP
I would appreciate if you guys create a node for Miro
Welcome to the community :partying_face:
Don’t forget to vote your self. :slight_smile:
If you need it ASAP, it could be worth it checking the community nodes if there is one or have a node builder build you a node.
Also, it would help if you have certain functions it needs to have to list them.
