paulg
November 11, 2024, 4:11pm
1
Hi, I am new to n8n so I presume I’m doing something wrong, but I’m having a couple of issues.
I can’t get the chat to work. It just continually gives me the typing gif:
Also, the “Stop listening” button doesn’t seem to do anything. I have clicked it three times and it still says “Stop listening”
Here is my setup for the chat:
I also tried submitting a form:
and when I hit submit, it still says it’s listening:
And, again, if I hit “Stop listening”, nothing seems to happen.
Thanks in advance.
n8n
2
n8n version:
Database (default: SQLite):
Operating system:
paulg
November 12, 2024, 2:53pm
3
Thanks for the quick response @n8n .
n8n version: most recent (v1.67.1)
db: postgres 16
EXCECUTTIONS_PROCESS: default
Running n8n via docker
operating system: ubuntu 20.04.2 LTS
Heres the docker-compose.yml file if you need it
version: “3.9”
services:
n8n:
image: n8nio/n8n:1.67.1
ports:
- “25678:5678”
environment:
- N8N_BASIC_AUTH_ACTIVE=true
- N8N_BASIC_AUTH_USER=<N8N_User>
- N8N_BASIC_AUTH_PASSWORD=<N8N_Pwd>
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=db
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_DATABASE=<DB_Name>
- DB_POSTGRESDB_USER=<DB_User>
- DB_POSTGRESDB_PASSWORD=<DB_Pwd>
- NODE_FUNCTION_ALLOW_EXTERNAL=axios,qs
- WEBHOOK_URL=
depends_on:
- db
restart: unless-stopped
db:
image: postgres:16.0
volumes:
- db-data:/var/lib/postgresql/data
environment:
- POSTGRES_USER=<DB_User>
- POSTGRES_PASSWORD=<DB_Pwd>
- POSTGRES_DB=<DB_Name>
volumes:
db-data:
paulg
November 12, 2024, 4:50pm
6
Sorry for the multiple posts. I didn’t realize my posts were getting automatically flagged and hidden.
Jon
November 14, 2024, 12:30am
7
Hey @paulg
To start it would be worth dropping the n8n_basic_auth options, they have not been used in over a year. Oddly I have seen people using them a few times did you use some AI or an outdated tutorial to set up n8n?
Looking at the issue you have described it sounds like maybe you are using nginx as a reverse proxy and have not configured it to use websockets, if you are not using nginx can you let me know.
paulg
November 14, 2024, 2:39am
8
Thanks @Jon
I did resolve this today and jsut didn’t get around to posting here yet. It was an Nginx issue that was blocking the SSE
system
Closed
February 12, 2025, 2:39am
9
