Having Issue while updating to from 0.234.1 to 1.22.6
FROM ubuntu:20.04
	#### SET THIS ARGUMENT TO THE DESIRED N8N VERSION ####
		ARG N8N_VERSION
		RUN if [ -z "$N8N_VERSION" ] ; then echo "The N8N_VERSION argument is missing!" ; exit 1; fi
	#### INSTALLING PRE-REQUISITES AND NODE-18 ####
		RUN \
			apt-get update
		RUN \
			apt-get -y install curl git gosu && \
			apt-get install build-essential python2 -y && \
			cd ~
		RUN curl -fsSL https://deb.nodesource.com/setup_18.x | bash -
		RUN apt-get -y install nodejs
	#### SETTING CUSTOM USER TO RUN N8N ####
	USER \
		root
	#### IMPORT N8N SOURCE-CODE FOR ASKED VERSION ####
		RUN \
			mkdir n8n && \
			chown -R root ./n8n && \
			git clone --depth 1 --branch "n8n@"${N8N_VERSION} https://github.com/n8n-io/n8n n8n
		WORKDIR n8n
	#### OVERRIDING N8N FILES TO CUSTOMIZED ONES ####
#		RUN \
#			rm ./packages/cli/src/Logger.ts ./packages/cli/src/Server.ts
#		COPY \
#			wrapper/packages/cli/src/Logger.ts ./packages/cli/src/Logger.ts
#		COPY \
#			wrapper/packages/cli/src/Server.ts ./packages/cli/src/Server.ts
	#### INSTALL AND ENABLE COREPACK AND ACTIVATE PNPM FOR BUILD MAKING ####
		RUN npm install -g [email protected] full-icu
		RUN \
			npm install -g corepack && \
			corepack enable && \
			corepack prepare --activate
	# Add Datadog tracing library
		RUN pnpm add dd-trace -w
	#### CREATING N8N BUILD ####
		RUN \
			npm_config_user=root && \
			pnpm install --frozen-lockfile && \
			pnpm install && \
			pnpm build
	ENV \
		NODE_ICU_DATA /usr/local/lib/node_modules/full-icu
	RUN export NODE_OPTIONS=--max_old_space_size=8192
	ARG N8N_BASIC_AUTH_ACTIVE
	ENV N8N_BASIC_AUTH_ACTIVE=${N8N_BASIC_AUTH_ACTIVE}
	ARG N8N_DEFAULT_BINARY_DATA_MODE
	ENV N8N_DEFAULT_BINARY_DATA_MODE=${N8N_DEFAULT_BINARY_DATA_MODE}
	ENV N8N_VERSION=${N8N_VERSION}
	ENV NODE_ENV=production
	#setting AWS creds in env
	ARG AWS_ACCESS_KEY_ID
	ENV AWS_ACCESS_KEY_ID=${AWS_ACCESS_KEY_ID}
	ARG AWS_SECRET_ACCESS_KEY
	ENV AWS_SECRET_ACCESS_KEY=${AWS_SECRET_ACCESS_KEY}
	ARG AWS_DEFAULT_REGION
	ENV AWS_DEFAULT_REGION=${AWS_DEFAULT_REGION}
	#installing aws-cli
	RUN \
		apt-get update && \
		apt-get install unzip && \
		apt-get install -y python3-pip
	RUN \
		curl "https://awscli.amazonaws.com/awscli-exe-linux-x86_64.zip" -o "awscliv2.zip" && \
		unzip awscliv2.zip && \
		./aws/install
	####  SETTING DOCKER ENTRYPOINT ####
	COPY \
		wrapper/docker/docker-entrypoint.sh /docker-entrypoint.sh
	RUN \
		chmod +x /docker-entrypoint.sh
	ENTRYPOINT \
		["/docker-entrypoint.sh"]
version: '3.2'
services:
  n8n:
    container_name: n8n_ent_app
    build:
      context: .
      dockerfile: Dockerfile
      args:
        - N8N_VERSION=1.22.6
        - N8N_BASIC_AUTH_ACTIVE=false
        - N8N_DEFAULT_BINARY_DATA_MODE=filesystem
    # restart: always
    command: /docker-entrypoint.sh
    ports:
      - 5679:5678
Hey @Gouravdev,
What error are you seeing now?
Quick update I have just managed to build the below, So maybe you can start with that.
FROM ubuntu:20.04
		ARG N8N_VERSION
		RUN \
			apt update
		RUN \
			cd ~
	USER \
		root
		RUN \
			mkdir n8n && \
		WORKDIR n8n
		RUN \
		RUN \
			pnpm install && \
			pnpm build
	ENV \
	#COPY \
	#	wrapper/docker/docker-entrypoint.sh /docker-entrypoint.sh
	#RUN \
	#	chmod +x /docker-entrypoint.sh
	#ENTRYPOINT \
	#	["/docker-entrypoint.sh"]
Which OS and version you’re using!!
Hey @Gouravdev,
I am using a MacOS 14.2.1, I have also managed to run the same build on Ubuntu 20.04 on a different machine.
