I want to use postgres to stock some data during workflows. I set up the postgres container and I can reach it using postbird form my machine.
When I set up the credentials in N8N, it doesn’t work. It tries to test the connection without succeeding.
I used the same credentials I used with postbird.
As host I used the public ip of my VPS, although the containers are in the same network. I also tried using the ip of the network, without success.
- n8n version: 1.81.4
- Database (default: SQLite): SQLite
- Running n8n via (Docker, npm, n8n cloud, desktop app): Docker compose
