Hello, Maybe someone have this problem: I often g
et ‘can’t show data’ in my flow. Why?
Hi @srocket.tech, welcome!
Your condition isn’t met, it’s false:
So you won’t get any output in the true branch,
However, you should still get an output in the false branch,
If you can share more details, we can figure out the issue, It’s hard to see much from that screenshot alone..
Hi, thank you for answer!
Look, the problem is that the flow breaks at any node. It can even be that it arrives at the webhook immediately ‘
can’t show data’
The execution of agents can also be broken, in this case, what I reset breaks the execution on if for some reason, then the branch continues to go, but the next node does not receive any information, because in the previous node ‘can’t show data ‘
