Help building an AI-powered cold calling notes workflow in n8n
Hi n8n community!
I’m trying to build a workflow in n8n (local instance) that automates creating “cold calling notes” for prospects, and I could use some guidance or collaboration from someone experienced. Here’s what I want it to do:
Objective:
Given a list of prospect design companies , the workflow should automatically generate a structured note containing:
– Prospect Note –
Design Project:
  • A specific, completed interior design project from the company’s website or portfolio.
  • Example: "The Gilded Nest" — the actual name of a project they have done, not just a type of project.
Focus Area:
  • The main specialization of the prospect.
  • Examples: Residential, Commercial, Luxury Interior Design.
  • This should reflect what kind of projects they focus on, based on their website, portfolio, or LinkedIn.
Social Media Presence:
  • A summary of the prospect’s social media activity, ideally for Instagram, LinkedIn, or other relevant platforms.
  • Includes:
    • Activity Level: High / Medium / Low — based on number of posts, engagement, or general activity.
    • Followers: Number of followers (approximate is fine).
  • Example: "High activity" - 12,000 followers
The notes should be concise, standardized, and ready for cold calling outreach — really simple and easy to read.
EXAMPEL :
Desired Workflow Steps:
1. Input
  • List of prospect companies via Google Sheets.
  • Include fields such as: website link, Facebook link, LinkedIn link, business name, owner’s name, etc.
2. Search / Data Gathering
  • Ideally, search for information automatically using the website link (e.g., Redirecting... ).
  • I think there’s a node that can perform searches or fetch website data.
3. Summarization via AI (my biggest challenge)
  • Use OpenAI GPT (ideally GPT-5 mini or GPT-4) to filter and structure the information into the note format described above.
4. Output
  • Save the structured notes to Google Sheets, CSV, or Notion for easy access.
  • Notes should appear in a column to the right of the specific prospect.
Optional / Advanced:
  • Include a web scraping step to automatically check Instagram or LinkedIn for social media activity.
  • Rate social media activity as High / Medium / Low based on followers and post frequency.
What I’m Looking For:
  • Tips on prompting GPT to consistently return structured notes.
  • Advice on optionally integrating social media metrics.
  • Any workflow templates or examples that are similar.
Thanks so much in advance! I’d love to collaborate or see any examples of workflows like this.
Take a look at this Node which can help you with your LinkedIn profile extraction and doing outreach on LinkedIn:
