HELP! Dark Mode Not Fully Applying to Sidebar in v1.84.3
Hi everyone,
I’m running into a UI issue with dark mode in the latest version of n8n (v1.84.3).
When I enable Dark Theme, most of the UI switches over correctly — but the left-hand sidebar (navigation panel) remains white. This includes the section with links like “Workflows,” “Executions,” “Settings,” etc. It creates a visual inconsistency that seems unintended for dark mode.
This feels like a missing style or UI regression in this version.
:test_tube: What I’ve Tried:
• Confirmed I’m on n8n v1.84.3
• Tried clearing browser cache
• Used “Empty Cache and Hard Reload” in Chrome
• Logged out and back in
• Restarted the n8n server and terminal
n8n version: 1.84.3
Database: SQLite (default)
n8n EXECUTIONS_PROCESS setting: main
Running n8n via: npm (globally installed, self-hosted)
Operating system: macOS (Sonoma, M1 chip)
Browser(s) tested: Chrome and Safari (latest)
Theme setting: Dark (set via UI)
:speech_balloon: What I’m Looking For:
• Is this a known issue in recent versions?
• Is there a proper workaround or fix beyond manually injecting CSS or using Stylus?
• Should I consider reverting to a previous version where dark mode worked fully?
Happy to provide screenshots or more system info if needed.
Thanks in advance — really appreciate any insights!
— José
I would wager this is a potential caching issue of some kind. Or perhaps the browser you are using does not properly respect the styling keys.
It could be a bug, but I have not seen this myself yet.
Thats interesting it worked in prior version. Have you tried relogging? Forcing clearing browser cache? Using on firefox also cause the same issues?
