HELP! Document Organiser
I’m trying to find an AI-based solution for recognising + tagging + organising relevant project docs from a doc repo based on doc’s metadata.
I have absolutely no tech background, but would to learn and figure out how to do this.
Hey @cheese9254,
n8n isn’t a document management solution but in theory if you have the time and you are working with a storage provide we support you could probably make a workflow to handle this.
What are you currently using to store your files?
