Some one have figure out for this trigger how works?
i have created app
i have subscribed page with never expire token to the app leadgen
i have add webhook with never expire token on the page
i have set credential with all permissions
i have try to use the lead testing tool but im stuck the trigger not received anything
Facebook Lead Ads only allows you to register a single webhook per app. This means that every time you switch from using the testing URL to the production URL (and vice versa), Facebook Lead Ads overwrites the registered webhook URL.
You may have trouble with this if you try to test a workflow that’s also active in production. Facebook Lead Ads will only send events to one of the two webhook URLs, so the other will never receive event notifications.
