Such “value of object to key” transformations are a bit hard to achieve because the mapping here is custom, so right now there is no pre-built node for this.
However, if you are okay with using JavaScript, something like this should do the job:
This would return a single “attributes” array with key/item pairs such as "neutered": false:
Going forward it’d be great if you could paste your existing JSON data as text rather than take a screenshot. This will make it much easier for other users to reproduce the data structure (and help) without having to type it themselves.
