Help me create lead generation automation for apollo using n8n
Pls help me create a web scraper using apollo.io api so that i could get 1000 people data at once pls help
Hi @Arsh_Tyagi, welcome to the community.
We don’t usually build complete and complex automatons here on the forum. Do you struggle with a specific operation in n8n? If so, could you share the details requested in the question template here on the forum (like the n8n version you have in use, a workflow using which your problem can be reproduced, or example data)?
If you need someone to build your workflow for you, you could however reach out to an n8n expert via the Find an n8n expert form over on n8n experts.
